Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Commission setting problem
- This topic has 6 replies, 3 voices, and was last updated 6 years, 8 months ago by
Kelanvest SB.
- July 9, 2019 at 3:38 am #71631
Kelanvest SB
ParticipantI’ve updated everything to latest version.
I’ve added codes in child theme that my transaction fee (5%) should include shipment. But still it doesn’t count it.
I assume item $6, shipping $10, fee 5% –> so admin get $16*0.05= $0.8, vendor get $16-0.8 = 15.2 (shipping by vendor). Is it correct?
Can you teach me how to fix it?
You must be logged in to view attached files. - July 10, 2019 at 2:11 am #71762
Kelanvest SB
ParticipantOK I found the solution. Solved.
The shipping option must come from the vendor store. Previously the shipping I set from admin site.
- July 11, 2019 at 7:14 pm #72065
fernandobrenes
ParticipantHi @Kelavest
I’m having the same issue however, could you please explain this: “The shipping option must come from the vendor store. Previously the shipping I set from admin site.”
Can you provide me a screenshot to see where you set this?
Thank you,
Best Regards - July 13, 2019 at 6:55 am #72240
You have to setup store shipping – https://wclovers.com/knowledgebase/wcfm-marketplace-store-shipping/
- July 13, 2019 at 7:02 am #72242
fernandobrenes
Unfortunately, I already did.
Please see
https://wordpress.org/support/topic/shipping-cost-goes-to-vendor/#post-11726175
Best regards
- July 15, 2019 at 4:50 am #72506
I think, shipping cost package is no generating for vendor, so it’s not visible to vendor and cost is not considering.
Can you please show me screenshot for “Order 2409” details from wp-admin -> WooCommerce -> Orders
Between, do you have any third party shipping plugin?
If yes, then please disable that and check once.Thank You
- July 15, 2019 at 10:16 am #72527
Kelanvest SB
ParticipantIf you are logging in as an admin, go to Vendor -> select a vendor -> enable shipping & set shipping fees.
Remember the two short codes.
I had spent whole 2 days in troubleshooting this issue. Hope it helps.
