Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Duplicate Product not Working
- This topic has 10 replies, 2 voices, and was last updated 6 years, 1 month ago by
Eric Smith.
- April 28, 2020 at 1:03 am #123880
Eric Smith
ParticipantI have added the code from here.
https://wclovers.com/forums/topic/duplicate-product-button-in-the-edit-product-screen/To my functions.php and the button adds on the product screen. But it does not actually do anything the wheel just spins forever.
Is this the best way to even give my vendors this functionality?Please help.
Thanks,Attachments:
You must be logged in to view attached files. - April 28, 2020 at 11:38 am #124068
The code provided there works fine. There seems to be some ajax related error on your site.
Also check in Google Chrome Browser console, is there any JavaScript error happening to the site or not! (What is browser console – https://support.airtable.com/hc/en-us/articles/232313848-How-to-open-the-developer-console)
Thank you! - April 28, 2020 at 11:56 pm #124414
Eric Smith
ParticipantThis reply has been marked as private. - April 29, 2020 at 12:45 pm #124540
KeymasterHello,
It’s an old entry, from 2020-04-01. Is there something more recent (today or yesterday)?
Looking forward to helping you. - April 29, 2020 at 9:24 pm #124738
Eric Smith
ParticipantThere are no current fatal errors.
I think this is the relevant error from thee chrome browser.
Failed to load resource: the server responded with a status of 400 (Bad Request)
DevTools failed to load SourceMap: Could not load content for https://redwoodartgroup.com/wp-content/themes/tm-heli/assets/libs/datepicker/bootstrap-datepicker.standalone.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILUREBut what should I do? I need to be able to duplicate products. Is this even the best way? Is there something else I can try?
- April 30, 2020 at 10:28 pm #125162
KeymasterHello,
This error is not related with WCFM or the code that was provided.
This comes from a library used by your theme. Apparently this issue was resolved some time back. Are you using an older version of the theme? If yes, then please update.
I also search for this error and found this link with a probable solution- https://stackoverflow.com/questions/21773376/bootstrap-trying-to-load-map-file-how-to-disable-it-do-i-need-to-do-it
Let me know if it works.
Thank You! - May 19, 2020 at 9:06 pm #133180
Eric Smith
ParticipantMy theme is up to date.I still can’t find a resolution for this. My vendors really need it. Is there some other place I can look for an error? I can make you a vendor and give you permissions to recreate the issue.
- May 19, 2020 at 9:32 pm #133186
KeymasterOk, send me the access also reach out to your theme author and see what they say about this. Thank You!
- May 19, 2020 at 9:50 pm #133190
Eric Smith
ParticipantThis reply has been marked as private. - May 19, 2020 at 10:25 pm #133206
To make this code work, you’ll need WCFM Ultimate. Without that, it will not work. I should have asked you that before. Sorry about that. You can now destroy our access.
Let me know if there is anything else I can help you with.
Thank You! - May 20, 2020 at 12:53 am #133273
Eric Smith
ParticipantThanks for your help. This is solved.
- The topic ‘Duplicate Product not Working’ is closed to new replies.
