Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Group the Ultimate documentation together
- This topic has 3 replies, 2 voices, and was last updated 6 years, 2 months ago by
Avinaba.
- April 25, 2020 at 8:39 pm #122967
tideon
ParticipantDear Support,
One of the difficulties that I am having is knowing what documentation is under just the Ultimate plugin. I bought the plugin, but here on your site you have everything just scattered. They are not grouped together. You have so many features and different plugins, that for a new customer it is really difficult to separate what documentation goes with the ultimate and what comes with the standard plugin.
Take a simple example. You have a page for the ultimate with the features listed, but you fail to add hyperlinks to the specific sections/documentation.
You need to group your documentation by product.Also I have noticed that alot of your documentation is outdated. And often you speak of a feature, but does not show how to get to it. So there is no context.
Kind regards,
Customer - April 25, 2020 at 9:11 pm #122978
Avinaba
MemberDear @tideon,
Thanks for sharing your views and we will definitely take a serious note on this, infact we are already working on creating a new documentation site here – docs.wclovers.com and will cover all the modules soon!.
Also note that these new documentations will be aligned to the latest development and hence updated. So no worries.
Hopefully we will be able to resolve issues for valuable customers like you soon 🙂
- April 26, 2020 at 11:58 am #123167
tideon
ParticipantDear Avinaba,
This is good to hear. Here is an example of a page that talks about a feature https://wclovers.com/knowledgebase/wcfm-toolset-types/
But I cannot see which menu I have to head to, nor does your document say where to find it. You also cut off the screenshot in away that we cannot see it’s context.Also I am not sure if this is a separate plugin or a part of ultimate or just apart of the standard install.
My suggestion would be to have a “mode” where you highlight the ultimate features, because as a new user, I can’t tell what is new from what was there from the standard install. - April 27, 2020 at 1:17 pm #123588
- The topic ‘Group the Ultimate documentation together’ is closed to new replies.
