03Day 19Hr 28Min 23Sec
How could i add custom divid categories for product
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › How could i add custom divid categories for product
Viewing 5 reply threads
    • #27372
      MOHO
      Hi
      I use “https://facetwp.com/” for Advanced Filtering for WordPress.
      So i will create like animal categories different than product categories.
      I want to provide multi categories for user to search, so only one categories is not satisfy for me.
      But how could i add new “animal categories” on the top of original product categories?
      by moho
    • #27398
      d-n-13
      Hello
      add this code in your function.php
      function ess_custom_taxonomy_Item() {
      $labels = array(
      ‘name’ => ‘Animals’,
      ‘singular_name’ => ‘Animal’,
      ‘menu_name’ => ‘Animals’,
      ‘all_items’ => ‘All Animals’,
      ‘parent_item’ => ‘Parent Animal’,
      ‘parent_item_colon’ => ‘Parent Animal:’,
      ‘new_item_name’ => ‘New Animal Name’,
      ‘add_new_item’ => ‘Add New Animal’,
      ‘edit_item’ => ‘Edit Animal’,
      ‘update_item’ => ‘Update Animal’,
      ‘separate_items_with_commas’ => ‘Separate Animal with commas’,
      ‘search_items’ => ‘Search Animals’,
      ‘add_or_remove_items’ => ‘Add or remove Animals’,
      ‘choose_from_most_used’ => ‘Choose from the most used Animals’,
      $args = array(
      ‘labels’ => $labels,
      ‘hierarchical’ => true,
      ‘public’ => true,
      ‘show_ui’ => true,
      ‘show_admin_column’ => true,
      ‘show_in_nav_menus’ => true,
      ‘show_tagcloud’ => true,
      register_taxonomy( ‘Animals’, ‘product’, $args );
      add_action( ‘init’, ‘ess_custom_taxonomy_item’, 0 );
    • #27425
      Best to use – https://wordpress.org/plugins/types/
      Just create any no of custom categories for you Products and all will be visible at Product Manager, in fact I already see one is there “Brand” 🙂
    • #27438
      MOHO
      Hi WCFM
      “Brand” is theme default category, and i start to research “Toolset Types”, thanks a lot!
    • #27453
      MOHO
    • #27560
      You have created Product Fields.
      Create taxonomy for the product.
      You may check this once – https://wclovers.com/knowledgebase/wcfm-toolset-types/
  • The topic ‘How could i add custom divid categories for product’ is closed to new replies.
