Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › how to add custom field to store setup and address.. also about product add-ons
- This topic has 5 replies, 2 voices, and was last updated 6 years, 6 months ago by
- February 26, 2019 at 12:04 pm #50170
MarsMars
Thanks for this amazing amaazziinng product.. it saved my time .. within a day everything is ready woow.
I have these questions
1. I saw this ib one of the forum topics but not sure how to do it https://ibb.co/fYQbye adding additional info about vendor
2. I want to add one custom field in the store setup widget, how can add This
3. I want to add extra two to the address How to do it
4. I created a gobal add-on from the WP Admin > Product > Add-ons .. it worked fine .. but I want the vendors to use it and set the additional price since the price is not fixed between vendor ( here is the scenario assuming the product is hair dye ,, based on the gobal add (short, medium, long) .. each vendor will have different price for the service and the add on) so I want to have the addon global to all vendor (medium,long, short) .. but they set their on price and it will reflect to the total price in the cart.
5. is there away where I can add a google map picker to the product and checkout pages?Regards
- February 26, 2019 at 5:09 pm #50215
*** Well, these are vendor registration custom fields (https://wclovers.com/knowledgebase/wcfm-marketplace-vendor-registration/)
*** Possibly. But where? By adding a new Setup step or under existing steps?
*** Not getting this, what you want to add with address?
*** Well, WC Product Addon does not allow to edit Global Addons at product level.
*** Please use GEO my WP plugin for the purpose.
- February 26, 2019 at 5:57 pm #50218
MarsMars
Thanks for the quick reply
1. ok clear
2. I want to add a new step for coverage area for the service
3. I want to add a field for the neighborhood
4. is there another way to do it.
5. I will try it
6. do you have arabic translation for the modules ,, it is taking too long to translate through loco?Regards,
- February 27, 2019 at 9:47 am #50322
3. I want to add a field for the neighborhood– Well, this will be paid customization. If you are interested then reach us here – https://wclovers.com/woocommerce-multivendor-customization/
– No, WC Addons does not support this6. do you have arabic translation for the modules ,, it is taking too long to translate through loco?
– Sorry, WCFM does not have 100% Arabic translationThank You
- February 27, 2019 at 1:10 pm #50388
MarsMars
ParticipantThank you .. I emailed you regarding the needed customization
also can I use Elementor to customize the store list and store page?? - February 27, 2019 at 1:27 pm #50395
OK, we are checking your email.
Well, WCFM not yet compatible with Elementor!
- The topic ‘how to add custom field to store setup and address.. also about product add-ons’ is closed to new replies.
