Diwali
00Day 18Hr 00Min 14Sec
Diwali
Issues / discrepancies with store invoice an d packing slip
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Issues / discrepancies with store invoice an d packing slip
Viewing 17 reply threads
    • #51206
      shitT
      On my marketplace, the buyer buys directly from the vendor. The vendor ships the item in his own name.
      Using your product, there are following discrepancies:
      – The buyer get the store invoice ins email confirmation (good), but sees the marketplace invoice his order list online (not good). Could you make sure the buyer gets only the store invoice, not the marketplace invoice?
      – The vendor gets a marketplace packing slip instead of a store packing slip. This only makes sense in a dropshipping model, not in a true marketplace model. Could you please create a store packing slip in a next release?
      – The store invoice doesn’t use the shop logo. no idea why (see attachment). The store logo is set for the shop (using WCFM and WCMMp). Is it a bug or did I miss something?
      – The store invoice lists policies per article. Makes no sense for me, as the policies are set on shop level. Could you replace this by the shop policies?
      Thanks for your answers!
    • #51309
      *** You may disable main site invoice from PDF Invoice plugin’s setting panel.
      *** Why so, if vendors are generating Packing Slip from there dashboard it’s not with their store name and address? Then possible you not yet setup vendor’s invoice configuration!
      *** Please check this – https://wclovers.com/knowledgebase/wcfm-store-invoice/
      Possibly you missed vendor’s Store Invoice configuration. It’s very important for all these!
      *** Well, vendor’s are allowed to override policies at product level, so it’s showing policies for each item separately!
      Still, there is an option under Store Invoice setting to disable policies.
    • #52568
      shitT
      Thanks for your explanations. I understand better and the distribution of invoice and packing slips is correct. The main site invoice had to be disabled.
      I still have the issue with the logo. Setting are correct (see attachment), but logo does not appear on invoice (see attachment). The store logo is set in the store configuration (see attachment). The current logo for this example is in *.jpg. I already tested if it was an issue with the file format (jpg, png, gif), but it didn’t work with any of these formats.
      What could it be?
    • #52774
      There is a separate setting option for Invoice Logo under “Invoice” tab.
    • #52818
      shitT
      I’m very sorry, but I can’t find this setting. Can you please show me where it is?
    • #52950
      Please go to WCFM Admin Setting -> Store Invoice -> Be sure Vendor Logo is ON – > https://ibb.co/nzhtVsz
    • #53198
      shitT
      Hi
      Thanks for your answer. As you can see from the screenshot in the last mails, it is on. But it doesn’t work.
      What could it be? Is there any restriction for the logo format?
    • #53250
      What kind of restriction?
    • #53474
      shitT
      No idea, just guessing. I set everything as you said. Please tell me why it doesn’t work.
    • #53645
      Is Store logo visible for this vendor under his store page?
      Please show me screenshot for WCFM Admin Setting -> Store Invoice
    • #53655
      shitT
      Thanks for looking into this.
      The store logo is visible under his store page as well as in the store manager (see screenshots)
      I added the WCFM Admin Setting screenshot, as well as the store invoice.
    • #53660
      shitT
      Oops, here again the WP Admin screenshot…
    • #53740
      Ok, I think that image type not supported by PDF.
      Can you send me that image file to test once?
    • #53764
      shitT
      Ok, here you go.
    • #53945
      Thanks, we are checking this.
    • #54553
      Well, we have test using this logo and invoice generating perfectly – https://ibb.co/whqQp4S
    • #54673
      shitT
      Hallelujah! It works now here as well, after I updated WCFM today. Thanks a lot!
    • #54933
      Great … thanks fro the update 🙂
  • The topic ‘Issues / discrepancies with store invoice an d packing slip’ is closed to new replies.
