Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › New order sound notification not working
- This topic has 1 reply, 2 voices, and was last updated 5 years, 2 months ago by
- May 13, 2020 at 11:11 pm #130586
panabogdan12
I saw some user that wanted to remove the sound, i just want it to play but it doesn’t.
I have this settings, and the default sounds ok but nothing happens when a new order is added to the list.
“wcfm_is_desktop_notification”:”1″,
“is_mobile_desktop_notification”:””Can you tell me how to debug this?
Thank you. - May 14, 2020 at 1:56 pm #130880
Starting from v3.3.8 this feature is disabled by default due to performance issues. Previously our notification manager used to make an ajax call every 60 sec to check for any new events (like order, registration, etc). But this was causing higher bandwidth usage and overloading server CPU.
Please refer to this post for additional details https://wclovers.com/forums/topic/urgent-site-crashing-need-help-with-ajax-calls-frontendmanager/ It also includes the way to enable new notification checking (automatic).
Let me know if that helps!
Thank You!
