wcfm-santa
-364Day -6Hr -26Min -35Sec
wcfm-santa
Point of Sales (WePos) not working
Viewing 6 reply threads
    • #104830
      Alexis DUFAYS
      Finally the plugin doesn’t work : https://prnt.sc/qvqimj
      Here some users say it’s working : https://wclovers.com/forums/topic/woocommerce-pos/
      Even the developper of the plugin are saying it’s not working with WCFM : https://prnt.sc/qvqjzp
      So is there a way to make it works ? Or an other solution ?
    • #105619
      Alexis DUFAYS
      Almost 6 days and no answer… I even wrote to the premium support because yeah I bought your premium plugins and no answer too… That’s crazy !
    • #105683
      Sorry for delayed reply.
      Well, wePOS + WCFM => this integration comes form us, so if you contact wePOS plugin author then they can’t help you.
      WCFM perfectly works with wePOS.
      Please go to WCFM Capability setting and click “Save” once then test this as vendor user.
      Be sure you are using latest version of all the plugins – WooCommerce, WCFM, WCFM Marketplace and wePOS
    • #105757
      Alexis DUFAYS
      It’s working good thanks ! Is it possible to change the capability for different package ? For example I would like to offer POS feature for the most expensive package. How to do ? 🙂
    • #106405
      Different membership level different capability setting possible using WCMF – Group addon – https://wclovers.com/product/woocommerce-frontend-manager-groups-staffs/
    • #122937
      Kay
      Please see: POS Integration
    • #142212
      redgiov
