WCFM Anniversary
We've turned 8! Celebrate with us and take away upto 25% OFF on WCFM Addons.
03Day 06Hr 01Min 54Sec
WCFM Anniversary
Registration on WCFM not working –
Best Multi Vendor Marketplace Plugin for WordPress Forums WC Vendors Registration on WCFM not working –
Viewing 35 reply threads
    • #136216
      Davo McConville
      I have an issue – when I click “Login-Register” and try to Register a new user, it does not do the WCFM registration process
      How do I make the Register button go to the WCFM registration / dashboard?
    • #136217
      Davo McConville
    • #136436
      Please check the vendor registration documentation here – https://wclovers.com/knowledgebase/wcfm-marketplace-vendor-registration/
      Default registration form(WooCommerce registration form) used for customer registration.
      You will find Vendor registration page contain “[wcfm_vendor_registration]” shortcode.
    • #136465
      Davo McConville
      Hello Sarmistha – I have done all this correctly, but registration still does not lead to WCFM
      Can you help me today please? Thanks!
    • #136468
      Have you check the pages in your WordPress dashboard? Is there any page with this “[wcfm_vendor_registration]” shortcode? If not kindly create a page with this “[wcfm_vendor_registration]” shortcode and browse it. You will find the Vendor registration form.
    • #136476
      Davo McConville
      Hello yes that page is set, with this short code:
      [sc name=”wcfm_vendor_registration”]
      The page is named “Register” – is this correct?
      • #136485
        What is this? – [sc name=”wcfm_vendor_registration”] ??
        We have mentioned you the shortcode is – [wcfm_vendor_registration]
        PFA
    • #136477
      Davo McConville
    • #136480
      Davo McConville
    • #136484
      Davo McConville
      To be clear, what I want out of this is:
      • All Sign ups to the site create users who are buyers AND vendors
      • All users need to be approved
      • email verification
    • #136512
      Davo McConville
      OK I have changed the Register page to
    • #136515
      Davo McConville
      The page now works, thank you!
      However, when I click:
      Login/Register in my header, then “Register” – it does not correctly go to this page ([wcfm_vendor_registration])
      Can you help
    • #136520
      Davo McConville
      Another issue:
      When I register a new Vendor through [wcfm_vendor_registration], their default role is “None”, not “Vendor”
      Can you tell me where to modify this?
    • #136521
      Davo McConville
      Actually registration to WCFM still isn’t working
      The latest vendor I registered through [wcfm_vendor_registration] does NOT show in WCFM Store Manager
    • #136547
      >> This is your theme’s login/register form. Yes it will not open “Vendor registration” form here. You can add “Become vendor” link in after the header register form .
      function custom_wcfmmp_become_vendor_link() {
      	global $WCFM, $WCFMmp;
      		$hide_become_vendor = wcfm_get_option( 'wcfmvm_hide_become_vendor', 'no' );
      		if( apply_filters( 'wcfm_is_allow_my_account_become_vendor', true ) && ( $hide_become_vendor !== 'yes' ) && WCFMmp_Dependencies::wcfmvm_plugin_active_check() ) {
      			if( wcfm_is_allowed_membership() && !wcfm_has_membership() && !wcfm_is_vendor() ) {
      				echo '<div class="wcfmmp_become_vendor_link">';
      				$wcfm_memberships = get_wcfm_memberships();
      				if( apply_filters( 'wcfm_is_pref_membership', true ) && !empty( $wcfm_memberships ) && apply_filters( 'wcfm_is_allow_my_account_membership_subscribe', true ) ) {
      					echo '<a href="' . apply_filters( 'wcfm_change_membership_url', get_wcfm_membership_url() ) . '">' . apply_filters( 'wcfm_become_vendor_label', __( 'Become a Vendor', 'wc-multivendor-marketplace' ) ) . '</a>';
      				} else {
      					echo '<a href="' . get_wcfm_registration_page() . '">' . apply_filters( 'wcfm_become_vendor_label', __( 'Become a Vendor', 'wc-multivendor-marketplace' ) ) . '</a>';
      				echo '</div>';
      >>There is no “None” role in WordPress. If you turn-on “Required Approval” functionality for vendor registration, then by-default vendor will be registered as a “subscriber” role.
      You/admin have to approve vendor from “Notification dashboard” then it will display in “Store Vendors” in WCFM dashboard.(https://wclovers.com/wp-content/uploads/2018/08/wcfmmp_registration_approve.png)
    • #136549
      Davo McConville
      Hello, no – the last vendor who registered does not appear in Store Vendors.
      Please can you look at my site and help me specifically?
      Can the theme’s Login/Register be directed to [wcfm_vendor_registration]?
    • #136555
      Davo McConville
      What should these settings be in WooCommerce?
    • #136634
      Davo McConville
    • #137231
      Regarding vendor who registered does not appear in Store Vendors,
      Kindly provide us your site admin access(username/password), then we can check this. (Set as private reply)
      >>We have already replied you in this #136547 thread.
      >>Please check the WooCommerce Settings documentation here – https://docs.woocommerce.com/document/configuring-woocommerce-settings/
    • #137232
      Davo McConville
      Hello – so to be clear, there is NO way for:
      Login/Register (WooCommerce link) to direct to [wcfm_vendor_registration]
      I need this functionality. Can you suggest a workaround?
    • #137233
      Davo McConville
    • #137234
      Davo McConville
      Hi – when I asked what the settings in WooCommerce should be – so to use WCFM, the settings should be the WooCommerce default?
    • #137391
      WooCommerce Login/Register goes to [wcfm_vendor_registration]
      >>You must be aware our WCFM plugin has not any customization in WooCommerece registration form. So, Vendor registration via WooCommerce registration form is not possible using code snippet.
      It requires serious custom development, and this will be a paid one.
      Please be advised then normal-user/customer not able to register in your site. All users will be vendors.
      >>Yes
    • #137392
    • #137395
      Davo McConville
    • #137396
      Davo McConville
      oh i think you need to login at the wp-login page, no?
    • #137397
      Davo McConville
      Ok thanks – can you advise me on what to ask for the custom development?
      Yes, I only want users to be Vendors (because of course Vendors can also be customers, correct?)
    • #138240
      Davo McConville
      Hello? Why is it a 4 day wait, please?
      • #138296
        Please go through our previous reply #137402, we have asked you to provide correct credentials. Without correct credential, we can not login in your site, hope you understand.
        >>Due to COVID-19 we are getting 400-500 more support tickets each day. So we aren’t taking any customizations at this moment. If you can wait for a couple of months then we can start your customization work. If you are interested then please contact us here – https://wclovers.com/woocommerce-multivendor-customization/
        Otherwise, It will be better to find someone who is accustom to WP development. If you face any difficulty at the time of development we will guide you accordingly.
    • #138307
      Davo McConville
      Please can you tell me how to disable all non-vendor registration?
      So that my site can only accept Vendor registrations
    • #138308
      Davo McConville
    • #138345
      Davo McConville
      Hi Sarmistha,
      You registered at my site, name demovendor and with your Gmail address – can I ask what page you did that on? Because it did not register you as a WCFM vendor. Thanks
    • #138449
      The credential you have provided us, this is not admin credentials. Without login as an admin, we are unable to see your site settings.
      Also “https://unitbase.co.uk/my-account/&#8221; ,the WooCommerce default login page is not accessible.
      Previously we have registered from here – https://unitbase.co.uk/vendor-membership/, also this URL not working at present.
    • #138450
      Davo McConville
      This is now an administrator account, please try again
    • #138454
      Davo McConville
      The main issue right now is that the sidebar CREATE AN ACCOUNT link (that is accessed through the Login/Register at the top of the page)
      Does not function, it never redirects correctly.
      Thank you!!!
    • #138504
    • #138679
      Davo McConville
      Thank you – everything was working perfectly yesterday. The Login/Register opened a sidepanel, and both login and register worked
      Today nothing works. I don’t understand, I haven’t changed anything
    • #138908
      Hello
      >>Again we checked your site, and we can see you have created too many “My account” page, then assign the wrong page in WooCoomerce “Account” page settings.
      We have selected the correct “Account” page in WooCoomerce setting and now login is working correctly.
      Please be advised it’s very difficult for us to debug your site every day if you applied wrong settings every day.
      Hope you understand.
  • The topic ‘Registration on WCFM not working –’ is closed to new replies.
