Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Stripe Trial peroid
- This topic has 8 replies, 3 voices, and was last updated 5 years, 11 months ago by
- August 21, 2019 at 1:50 pm #77640
sdel_nevo
ParticipantHi Guys
I was reading the support posts at wordpress.org and came across this post
this is the same problem as I have faced,
the trial period is being ignored and the fee is taken straight away
will this be resolved in a coming update, it will be great to be able to offer trial periods
Steve
- August 22, 2019 at 5:25 pm #77836
MemberOK, we are checking this.
- August 22, 2019 at 6:04 pm #77865
sdel_nevo
ParticipantHi guys
Thanks, that will be fantastic
Steve
- August 24, 2019 at 1:39 pm #78170
Well, we have test this. In this case Stripe charge as per plan setting under Stripe account.
Now, Stripe does not support Trial Amount, trial period should be a FREE one! https://ibb.co/5cGfQGB
There is no option to set trail amount for Stripe plan – https://ibb.co/syqkbmy
So, if you set Trial period then it will not charge any amount at the time of subscription, otherwise it will charge First billing amount.
- August 24, 2019 at 4:13 pm #78176
sdel_nevo
ParticipantHi Guys
ok, but there was an issue with your split pay when using the free trial. the trial was being charged the full amount
for example
if I have a membership for £9.99 per month with a 1-month free trial
when vendors signed up, £9.99 was getting charged straight away, instead of £0I did raise this on the forums a while back
https://wclovers.com/forums/topic/trial-period-not-working-version-2-5-6/has that issue been resolved in previous updates? I haven’t seen that one listed on the changelogs
Steve
- August 25, 2019 at 7:47 am #78244
sdel_nevo
ParticipantHi Guys
I have just tested this on my staging site and can confirm that the free trial is not working
when signing up, the membership plugin says £0 but the test card is charged the full amount
Steve
- September 2, 2019 at 8:40 am #79568
me
ParticipantAny updates on this?
More than a week had passed.
Critical issues like this should at the very least receive a “will get back to you as soon as possible” type of vanilla answer, instead of simply refusing to reply once it gets difficult. - September 2, 2019 at 3:45 pm #79680
MemberWell, we have already replied the actual author if this topic over email, so do not replied here.
– If something is not possible by us or our addon we directly mentioned that. There is no chance of ignoring and hold things in our hand.
- September 18, 2019 at 10:01 am #82265
MemberHi Guys,
An update on this topic –
We have updated Stripe API (SCA Compatible) in latest WCFM Membership, 2.7
Stripe new API does not support “Trial Period” setting at Stripe Plan level at your Stripe account. if you have set anything their then remove that otherwise user will not able to pay using Stripe.
Trial period is still functional, you just have to specify that at WCFM Membership Manage -> Subscription tab
Stripe Trial period is always FREE as before.
- The topic ‘Stripe Trial peroid’ is closed to new replies.
