Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Vendor Registration form problems
- This topic has 20 replies, 4 voices, and was last updated 6 years ago by
- March 28, 2019 at 4:54 am #54875
pdishman
ParticipantSeveral things on the vendor registration form
1) Layout is messed up – see part of it in attachment
2) Where are fields coming from? City State/County etc. They are not part of vendor registration tab (see attached)
3) State/County field – it is a drop down field with nothing in it and you can’t type in the box
3) Order of Fields – how do I change?Thank you for your help
You must be logged in to view attached files. - March 28, 2019 at 1:16 pm #54992
Please check this – https://wclovers.com/knowledgebase/wcfm-marketplace-vendor-registration/
You have enabled “Address” fields.
- March 28, 2019 at 3:26 pm #55021
pdishman
ParticipantYes… I did enable address field. You did not respond to this support topic.
1) the layout is a mess – it needs to be fixed
2) state/county is a drop down with nothing in it and you can’t even type in the box (and where is that field coming from – I don’t want it to say state/county, I want to edit it.
3) I want to edit order of fields (how do i do that)
4)And I want city and state to be required – how do i do that?This needs to be fixed
Thank you for your help - March 28, 2019 at 5:12 pm #55039
Here is the template for this page – wp-content\plugins\wc-multivendor-membership\templates\vendor_registration.php
You may override this at your child theme\wcfm\membership\vendor_registration.php – now edit and change as per your requirement.
Between, this is template already looks edited, atleast style. This is not default style for this page! Please be sure you have set Membership and Registration pages at WCFM Admin Setting -> Dashboard Pages
- March 28, 2019 at 7:40 pm #55077
pdishman
ParticipantOk, so I did add an image (since you can’t add a feature image) and some text blocks to the page (vendor-membership). Apparently you are saying any added text or styling to page is going to break the form? That is to bad…
Also the registration form is something you should fix globally for everyone. I know that the order is preference on my part – but standard order is address, city, state, zip
Also the state/country field you have as drop down and it is empty and cannot be filled – that needs to be fixed
And if the address is check marked as required, then city, state and zip should also be set as required.Thank you so much for fixing this! π π
- March 29, 2019 at 4:49 pm #55215
Ok, so I did add an image (since you canβt add a feature image) and some text blocks to the page (vendor-membership). Apparently you are saying any added text or styling to page is going to break the form? That is to badβ¦
– If you change page styles then it will off course break. But you may off course style your custom contents.
Also the registration form is something you should fix globally for everyone. I know that the order is preference on my part β but standard order is address, city, state, zip
– We will change this order
– DO you have selected any country? If not, then choose. State field will populate with that country’s states.
- March 29, 2019 at 6:05 pm #55248
pdishman
ParticipantWell, as I have already said on the State drop down field, it appears that there is nothing in the drop down. There is nothing to select.
Also, please make sure that city, state and zip are marked as required
Thank you so much! π
- April 1, 2019 at 4:48 am #55521
Can you please share this registration page with me to check once!
- April 1, 2019 at 3:09 pm #55590
pdishman
ParticipantThis reply has been marked as private. - April 6, 2019 at 4:55 pm #56525
We have checked this. Possibly your theme or some other plugin added an additional “p” wrapper with all form elements and that breaks the total form style!
- April 22, 2019 at 8:27 pm #58962
- April 24, 2019 at 9:04 am #59139
We have checked this. Possibly your theme or some other plugin added an additional βpβ wrapper with all form elements and that breaks the total form style!
– I already told you reason for this. Your theme breaking this, please contact your theme author for fix for this. it’s beyond our hand.
- April 24, 2019 at 4:06 pm #59223
pdishman
ParticipantAh, did not realize that the state drop down was part of the form breaking. Have reached out to the theme developer. Are there any plugins that you could recommend that could be the problem..? I have tried deactivating my form plugins, but they were not it. I have many plugins all of which I need of course!
- April 25, 2019 at 7:32 am #59333
I think it’s due to theme, in general plugins does not modify such things.
Just try once by activate any WP default theme, it will be clear to you.
Also clear site caches before check.
- May 2, 2019 at 5:42 pm #60440
Membertest reply
- May 2, 2019 at 5:43 pm #60441
Bingal
Guestchecking …
- May 8, 2019 at 3:00 am #61114
pdishman
Participanttest
- May 8, 2019 at 3:10 am #61115
- May 8, 2019 at 3:12 am #61117
pdishman
ParticipantWeird… the attachment above is my post that it won’t let me post (been trying to post it for awhile now), I get the error msg that you see on the above attachment. but it seems i can post everything else, doesn’t make any sense…
- August 1, 2019 at 11:19 am #74713
iamsilentsavior
Participantcountry dropdown list is empty
how can it works ?????
- August 3, 2019 at 7:05 am #74962
Please go to wp-admin -> WooCommerce -> Setting -> check what you have set at “Selling Location” and “Shipping Location”?
- The topic ‘Vendor Registration form problems’ is closed to new replies.
