Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Views for templates WCFM-Ultimate not working
- This topic has 7 replies, 4 voices, and was last updated 6 years, 3 months ago by
david_kogan.
- December 21, 2019 at 4:12 pm #98344
Zeljo
I am not able to override template files (views folder) for WCFM-Ultimate for any template files. I put the folder /wcfmu/ in my theme, then I create a subfolder, for example, /wc_bookings/ and copy the file I want to override, but nothing happens, it does not seem to work. Why am I not able to override views from this plugin at all, because WCMF views override does work.
- December 23, 2019 at 11:16 am #98647
Please override this here – your child theme/wcfm//wc_bookings/
- January 3, 2020 at 4:39 pm #100724
Zeljo
ParticipantThis only works for WCFM, not for WCFM-Ultimate, the templating does not work, okay? Can I get some attention here, and get someone to actually check this? The template files I am not able to override this way are:
wcfmu-view-wcbookings-products-manage.php (plugin path /wc-frontend-manager-ultimate/views/wc_bookings/)
Check this on your side and you’ll see that it does not work, you can’t override these files from a WordPress theme.
- April 15, 2020 at 6:55 pm #119388
david_kogan
ParticipantDid you get any replay? The same problem I’m facing at the moment
- April 16, 2020 at 1:33 pm #119684
Sarmistha Chakraborty
Override also works for WCFM U.
“wcfmu-view-wcbookings-products-manage.php” -> this file is part of Product manager so it’s override not working as all codes written using hooks.
In fact it’s more easy to edit/manipulate this file. There has filter for each field groups, just change using that.
Please know us what exactly you want to change, We will guide you accordingly.Thanks.
- April 27, 2020 at 6:21 pm #123709
david_kogan
ParticipantI would like to override the
view/reports/wcfmu-html-report-sales-by-product.phpfile.Both
child-theme/wcfm/reportsandchild-theme/wcfmu/reportsare not working.Because My vendors are still seeing products sold by other vendors.
Also, man german translations are not working correctly when changing the .po files and .mo files there are still not loaded correctly so I need to change the domain for the translation to make it work.
- April 27, 2020 at 8:20 pm #123769
“view/reports/wcfmu-html-report-sales-by-product.php” – this file override is not possible because this file is part of wcfmu-view-reports-sales-by-product.php.
>>Sorry, we didn’t get you, in your vendor dashboard -> report section you can see other vendor’s products order report?Please for translate use “Loco translate” plugin, https://localise.biz/wordpress/plugin/beginners
Example:
WP dashboard -> Loco Translate -> Plugins -> select WCFM – WooCommerce Frontend Manager – Ultimate -> Select your site language(or click on New language and add your site language) -> search the string “Sales by product” and translate -> save.Thanks.
- April 27, 2020 at 8:40 pm #123778
- The topic ‘Views for templates WCFM-Ultimate not working’ is closed to new replies.
