Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Subscriptions › WC Subscriptions not charging renewal Stripe Split Pay
- This topic has 7 replies, 3 voices, and was last updated 6 years, 8 months ago by
sunilmalviya.codingkart.
- September 7, 2019 at 12:30 am #80501
Makers
ParticipantI’ve setup WC Subscriptions on my site and have only Stripe Split Pay enabled as the payment gateway. The issue I am having is the subscriptions set up correctly and charge the initial payment, but when the subscription tries to renew it fails and goes into an “on hold” status.
I contacted Woocommerce support and they believe this is an issue with stripe split pay not working correctly with subscriptions. They ran several tests using stripe split pay and then were able to make it work correctly using the default stripe gateway. Like I said the initial subscription charge and commissions work correctly, but renewals and other subscription features aren’t working with stripe split pay.
Thank you for your help.
Best regards
- September 7, 2019 at 4:56 am #80525
- September 9, 2019 at 12:50 pm #80813
MemberWe are checking this, whether it’s possible to charge automatically using Stripe Split pay API or not!
- September 10, 2019 at 6:19 pm #81084
Makers
ParticipantThank you for looking into this!
- September 14, 2019 at 8:49 pm #81601
Makers
ParticipantI have to be honest though. I’m not so sure the Stripe Split Pay would be a good solution as a payment gateway for subscriptions anyhow unless a lot more functionality is added.
For example all these features below are supported by using the regular Stripe gateway, but almost none of these features are supported for split pay currently. Only “subscriptions” as of now.
subscriptions,
subscription_cancellation,
subscription_suspension,
subscription_reactivation,
subscription_amount_changes,
subscription_date_changes,
subscription_payment_method_change,
subscription_payment_method_change_customer,
subscription_payment_method_change_admin,
multiple_subscriptions,Without these functions being added to the stripe split pay app, it’s not such a good option as a gateway for subscriptions at this time. Just my opinion, but seems obvious to me. It’s why we’ve decided to use the normal Stripe gateway in the meantime unless something changes in the future regarding this.
Best Regards and Thank you for your continued support it’s very much appreciated.
- September 15, 2019 at 12:32 am #81684
– Right, Stripe Split pay API does not support all such subscription options. It’s better to use default WooCommerce Subscription plugin for these.
- September 15, 2019 at 1:14 am #81719
Makers
ParticipantYes. We are using the default Stripe gateway now, but need help working through calculation issues. I’ve tried to detail these issues in a few other threads here in the WC Subscription forum. I writing this here so you’ll know these calculation issues are not resolved. It’s actually since switching I found one new one.
So I definitely need your assistance working through these issues in these threads below.
https://wclovers.com/forums/topic/renewal-subscription-commission-calculation-issues-bug/
Thanks again!
- October 30, 2019 at 7:39 pm #89671
Participanti have same problem
- The topic ‘WC Subscriptions not charging renewal Stripe Split Pay’ is closed to new replies.
