wcfm-santa
-364Day -16Hr -27Min -46Sec
wcfm-santa
WC Lovers
WooCommerce Frontend Manager - Multivendor marketplace vendor dashboard
Forum Replies Created
Viewing 19 posts - 1 through 19 (of 19 total)
  • in reply to: Translation issues #37327
    Thanks I managed to translate the string above but for a strange reason the string “Account Type” for Mangopay is not translating and I don’t know why.
    I attached another screenshot.
    The mangopay file is correctly translated because in the admin page it is translated.
    Regards
    in reply to: Using Add-ons with WooCommerce Appointments #25263
    Thank You !
    Yes Pricing is a part of Appointment but vendors won’t need it.
    in reply to: Using Add-ons with WooCommerce Appointments #25259
    Okay after searching in the capacity settings I reactivated it.
    Sorry for the inconvenience.
    Can I remove the “Pricing” and “Yoast SEO” panels in the same page for vendors ?
    Thanks !
    in reply to: Fatal error since the last update #24501
    Yes we can
    in reply to: Fatal error since the last update #24495
    in reply to: Fatal error since the last update #24487
    Yes they are both at the latest version 4.1.2
    No I didn’t change my hosting or anything else recently. I just update my plugins as usual.
    in reply to: Fatal error since the last update #24485
    I updated the Permalinks and I still get the same error :
    Fatal error: Uncaught Error: Call to undefined function get_home_path() in /home/horse759/public_html/ambassad-hair.com/wp-admin/includes/misc.php:204 Stack trace: #0 /home/horse759/public_html/ambassad-hair.com/wp-includes/class-wp-rewrite.php(1775): save_mod_rewrite_rules() #1 /home/horse759/public_html/ambassad-hair.com/wp-includes/class-wp-hook.php(286): WP_Rewrite->flush_rules(true) #2 /home/horse759/public_html/ambassad-hair.com/wp-includes/class-wp-hook.php(310): WP_Hook->apply_filters(NULL, Array) #3 /home/horse759/public_html/ambassad-hair.com/wp-includes/plugin.php(453): WP_Hook->do_action(Array) #4 /home/horse759/public_html/ambassad-hair.com/wp-settings.php(471): do_action(‘wp_loaded’) #5 /home/horse759/public_html/ambassad-hair.com/wp-config.php(105): require_once(‘/home/horse759/…’) #6 /home/horse759/public_html/ambassad-hair.com/wp-load.php(37): require_once(‘/home/horse759/…’) #7 /home/horse759/public_html/ambassad-hair.com/wp-blog-header.php(13): require_once(‘/home/horse759/…’) #8 /home/horse759/pu in /home/horse759/public_html/ambassad-hair.com/wp-admin/includes/misc.php on line 204
    I understand that WCFM never calls this function but I don’t get any error when WCFM is disabled.
    I don’t use WPML.
    in reply to: Missing translations #24483
    Thank you WCLovers !
    I remain at your disposal.
    in reply to: Fatal error since the last update #24482
    After disabling Mangopay and activating WCFM and WCFMu plugins I get this error :
    in reply to: Input type select for product name #17309
    Okay thank you for this information I am not interrested for the moment, maybe in the future.
    in reply to: Input type select for product name #17170
    Yes I understand.
    in reply to: Input type select for product name #17094
    Yes I understood that I can now add any product name I want in the array you created. Again thank you very much for that 🙂
    I will try to explain what I have in mind for the add product page.
    As vendors can now choose a name in a list, I wonder if we can do a bigger array with inputs like product name, price, category, duration (WC Appointments) for eg.
    The vendor could choose a product name and inputs like price, duration and category would be automatically prefilled with values.
    For example : “Coupe Homme”(product name) – 15$ (price) – “Homme” (category) – 15min (duration with WC Appointments)
    I hope you understand better what I’m trying to explain.
    in reply to: Input type select for product name #17083
    Yes this is working very well for me thank you very much !
    Do you think we can extend this to have a complete template with more values linked to this choice for a few products ?
    The idea is to prefill the add product page to give the vendor a better user experience.
    Thank You WC Lovers !
    in reply to: Input type select for product name #17063
    Okay great !
    So the names would be : “Coupe Homme” “Coupe femme” “Brushing” “Coupe enfant”
    in reply to: How can I edit the wcfm-appointments-dashboard page ? #14986
    Hi Shhiv,
    I just updated the plugins and I have to say I can feel a big difference in the UI ! Congrats !
    The issues seems to be resolved and I can also see the appointments in the calendar view with shop_staff account ! Awsome !
    Now I don’t need to hide it so this is fully resolved for my part.
    Thank you very much !
    Charlie
    in reply to: How can I edit the wcfm-appointments-dashboard page ? #14883
    Thanks a lot for your help !
    The wcfm_custom_manage_staff function is working well but the wcfm_is_allow_appointment_calendar function makes me an error 500.
    About the issue with Appointment List for staff login I get this error now : DataTables warning: table id=wcfm-appointments – Ajax error. For more information about this error, please see http://datatables.net/tn/7
    Regards,
    Charlie
    in reply to: How can I edit the wcfm-appointments-dashboard page ? #14827
    Yes I’m confortable with php.
    Charlie
    in reply to: How can I edit the wcfm-appointments-dashboard page ? #14816
    Ok so I want to be able to translate the page.
    And then I want to remove the sections “Manage Staff” and “Appointment Calendar” for the shop_staff users because it isn’t working with their capacity I think.
    Also the “Appointment List” section is not working properly for shop_staff users, is it normal ?
    Charlie
    in reply to: Adding translation #14785
