Forum Replies Created
luis.samouco
Participanthttps://wclovers.com/knowledgebase/wcfm-mappress-google-map/
See this link maybe it will help you
and check this pictures might help you!Anyways don’t use this post to ask your questions.
My question in this post is solved so DONT reply to this! Thank you
You must be logged in to view attached files.June 4, 2020 at 5:59 pm in reply to: How to remove map on regular shopping page and place city search short code the. #138356luis.samouco
ParticipantYou can remove the map using CSS. Go to your styls.ccs and add this code:
.wcfmmp-product-geolocate-wrapper .wcfmmp-product-list-map { display: none; visibility: hidden; }It worked for me So it just removes the MAP
luis.samouco
ParticipantThank you a lot for your reply! Thank you!
June 1, 2020 at 1:45 am in reply to: How to remove map on regular shopping page and place city search short code the. #137082luis.samouco
ParticipantI am literally looking for the same thing! I will wait to see the reply for your questions! 😀 Thank you for asking this!
May 6, 2020 at 7:24 pm in reply to: Registeration Form(Policy tab Label and Stor Social Set Up) #127533luis.samouco
ParticipantI just left a good review! If you want me to give more reviews and feedback in other places I am more than happy to do it! You guys deserve to be known for the best Marketplace plugin! <3 Thank you 😀
May 6, 2020 at 6:13 pm in reply to: Registeration Form(Policy tab Label and Stor Social Set Up) #127471luis.samouco
ParticipantThis was amazing! Everything got solved! Thank you so much for your help! I really appreciate your help! Thank you so much!
May 6, 2020 at 4:36 pm in reply to: Vendor Registration-Terms & Conditions and Privacy Policy #127432luis.samouco
ParticipantThat’s great! It worked very well! Thank you for your help!
May 3, 2020 at 4:30 pm in reply to: Vendor Registration-Terms & Conditions and Privacy Policy #126062luis.samouco
ParticipantI added that code and just one part moved the fill up forms stayed exactly the same. Is there anything else I could try? Sorry about it.
You must be logged in to view attached files.May 2, 2020 at 1:02 am in reply to: Vendor Registration-Terms & Conditions and Privacy Policy #125551luis.samouco
ParticipantThank you so much!!!!!! I was able to do it!
There is just one problem that came up after:
After the change I realised that the style of the registration has changed. Is there any CSS that I can add or anything else just to make it look like before?I have sent you 2 pictures to show the before and after.
Thank you so much for your support!
You must be logged in to view attached files.April 28, 2020 at 5:06 pm in reply to: Vendor Registration-Terms & Conditions and Privacy Policy #124209luis.samouco
ParticipantHello Sarmistha! Thank you so much for your help and thank for replying so fast!
I was able to fix the CSS problem! on the question number 2.But I still have the question on the first one. So I made this HTML code to insert on the side of the Terms and Conditions:
<a target="_blank" href="https://localchain.co.uk/privacy-policy/">Privacy Policy</a>I don’t necessarily want just to change the language but I want to add HTML code to that part. Where can I find the code and Add this one that I have made? (I have sent you an image that explains)
You must be logged in to view attached files.- AuthorPosts
