Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Shipping location + Front-end search/filter
- This topic has 18 replies, 2 voices, and was last updated 7 years, 7 months ago by
- August 12, 2018 at 8:51 am #28338
d-n-13
ParticipantHello wcfm,
I’m wondering if I can connect shipping and search together, maybe in the new wcfm marketplace plugin ?
The idea is:-
1 – Vendor chooses shipping country / state / city.
2 – Customers can use sidebar categories / search / filters to filter products by country / state / city.(Check Attached Screenshot).
My current method is :-
2 – Vendor chooses category called (cities) and it is not connected to shipping – vendor has to match his shipping options with every new product added
3 – Customers filter by category (cities).As you can tell my current method is not optimal.
Any advice or solutions ?
- August 12, 2018 at 8:52 am #28339
- August 16, 2018 at 9:34 am #28683
WCFM Marketplace has everything, please take a look – https://wclovers.com/knowledgebase/wcfm-marketplace-store-shipping/
- August 16, 2018 at 9:46 am #28687
d-n-13
I saw shipping by zone and shipping by country / state, but I still don’t know how I can filter front end store products by country / state
Note : WCfM Marketplace Shipping System isn’t working atm, please check this topic : https://wclovers.com/forums/topic/bugs-i-found-inside-lets-make-this-the-best-marketplace/
- August 20, 2018 at 5:54 am #28940
We are debugging this in your staging.
Kindly share FTP for that site.
Thanks fro your cooperation.
- August 20, 2018 at 10:47 am #28960
d-n-13
ParticipantThis reply has been marked as private. - August 20, 2018 at 10:50 am #28962
MemberThanks for the F** details.
We are looking into the shipping issue.
- August 20, 2018 at 12:07 pm #28978
This has been resoled, you may check this now.
- August 20, 2018 at 12:46 pm #28980
d-n-13
Thanks I’ll be checking now,
May I know what was the issue ? related to theme / plugin / wcfm marketplace ?
- August 20, 2018 at 1:06 pm #28982
There was a WC hook dependency issue with Booster plugin.
- August 20, 2018 at 1:44 pm #28985
d-n-13
There is another bug related on having Flat Rate + Store Shipping together in the same region.
1- I have Flat Rate and Store Shipping : https://imgur.com/1OQ1nuA
2- I set all 3 shipping methods as vendor : https://imgur.com/N9G0bDL
3- It will not show “Flat Rate22” from vendor settings, only “Flat Rate” from Admin : https://imgur.com/nx3XXVr
Note : I tested this in another region without having admin “Flat Rate” and I had no problem.
- August 20, 2018 at 2:02 pm #28995
d-n-13
1- Disabling shipping from WooCommerce > Settings > Shipping > Marketplace Shipping should hide the settings in vendors shipping settings :
2- Is it possible to force vendors to add at least 1 shipping method before they can sell ? it will be hard to make sure every vendor have shipping settings done.
- August 20, 2018 at 2:45 pm #29001
d-n-13
Participant3- Please add an extra delete confirmation message when deleting a shipping method, I just tried to click Edit, and clicked Delete by mistake, afraid vendors will have the same mistake with no delete confirmation message.
- August 20, 2018 at 4:29 pm #29010
We will resolve this in next update.
You are right, vendor method should override admin method for vendor’s product.
Thanks for pointing this out.
- August 20, 2018 at 4:33 pm #29011
– Right, it’s a bug
– will check this, as shipping setting has many capability options as well. So disable selling without shipping may be conflicting one. Have to check this one!
– Definitely will add in next update.
Thanks for such detailed testing, really appreciate your effort.
- August 22, 2018 at 2:35 pm #29188
WCFM Marketplace 1.0.3 hs been updated.
– Resolved
– Confirmation added
- August 22, 2018 at 2:37 pm #29190
MemberWell, shipping other issues also resolved.
Kindly check other Shipping issues you have mentioned.
- August 23, 2018 at 1:48 am #29271
d-n-13
It seems that I cannot find any more issues in shipping.
There is one issue related to shipping setting though you can find it here : https://wclovers.com/forums/topic/finally-wait-is-over-lets-begin-a-new-era-with-wcfm-marketplace/#post-29245
Also this topic is actually opened for another matter but I already posted the suggestion here : https://wclovers.com/forums/topic/finally-wait-is-over-lets-begin-a-new-era-with-wcfm-marketplace/#post-29242
Other than that the shipping system is the best that you can find compared to all other multi-vendor plugins!
You can close this topic,
Thank You !
- August 23, 2018 at 5:07 am #29289
That’s really great to know 🙂
I will definitely that other thread.
- The topic ‘Shipping location + Front-end search/filter’ is closed to new replies.
