00Day 08Hr 08Min 06Sec
WC Lovers
WooCommerce Frontend Manager - Multivendor marketplace vendor dashboard
Forum Replies Created
Viewing 25 posts - 1 through 25 (of 513 total)
  • sdel_nevo
    in reply to: Main product categories #97374
    sdel_nevo
    Hi Guys
    sorry what I meant to say in the post above is
    if no category selected, please replace the “Product successfully saved” message
    with the red warning, category required
    steve
    in reply to: Duplicate products #97321
    sdel_nevo
    Hi Craig
    Yes mate
    Put it in your functions.pho file
    Steve
    in reply to: Main product categories #97258
    sdel_nevo
    Hi Guys
    the only issue I have found after adding this is
    i have set Categories are required” when adding products
    if no category is entered, the warning is not displayed in red after adding this code
    but the product is placed into draft mode 🙂 and not published
    is it possible with this code added
    to also show the error when no category has been selected
    really sorry to be a pain
    Steve
    in reply to: Bulk Edit #97257
    sdel_nevo
    Thank you guys, this will help alot
    Steve
    in reply to: Duplicate products #97256
    sdel_nevo
    Hi Guys
    that’s great, works brilliantly
    many thanks
    Steve
    in reply to: Main product categories #97255
    sdel_nevo
    Hi Guys
    OMG this is fantastic, thank you so much
    it’s going to help out brilliantly
    Steve
    sdel_nevo
    Hi guys
    “Possible to make this work only if one order has one vendor’s products“
    How can we implement that,
    If this is the only way that direct charges can work and be SCA compliant then this is the only option we have
    Please can you tell us how I can use direct charges this way
    Steve
    in reply to: Reviews Captcha #96934
    sdel_nevo
    Hi Mate
    give Advanced noCaptcha & invisible Captcha ago
    it has the added bonus of putting captcha in the contact forms and vendor signups
    Steve
    in reply to: Stripe Error – Invalid source object #96873
    sdel_nevo
    hi Jamie
    “We found another bug as well that was messing up the destination of the shipping fee and the commission in Stripe so had to hack that too.”
    what issue was that mate, I have a problem with the shipping commission, that I can’t get my head around,
    this may be related
    Steve
    sdel_nevo
    Hi
    this document https://stripe.com/docs/connect/charges-transfers#reversing-transfers is what I was sent via stripe, but it seems that there no way to claim money back from a connected account
    Steve
    sdel_nevo
    Hi again
    So if we implemented this does that mean that customers payments can be held in our stripe account for longer than 7 days?
    What we are looking to do is
    Customer pays for product
    Money held in our stripe account for 15 days
    At this point we pass to the vendor
    This will enable funds to be available if a refund is requested, as we are now liable for this
    Is this possible?
    If its not and the money is passed from our stripe account to our bank account after 7 days how do we handle refunds
    Steve
    sdel_nevo
    Hi guys
    So if we switched to that method, is it still SCA and 3d secure?
    Will vendors who have already connected there stripe accounts need to reconnect them
    Steve
    in reply to: Stripe split payment – stripe connect not configured #96636
    sdel_nevo
    That’s great
    you’re most welcome
    Steve
    in reply to: Stripe split payment – stripe connect not configured #96624
    sdel_nevo
    you’re more than welcome mate
    it works well for me,
    hope you’re able to make use of it
    Steve
    in reply to: Stripe split payment – stripe connect not configured #96621
    sdel_nevo
    Hi
    i had the same question ages ago, i purchased some code via a custom job
    this works for me really well, it prevents the vendor publishing products until the stripe account has been connected
    //  vendors can import them and assign a category, but products must not be published until a stripe account is connected
    add_action( 'after_wcfm_products_manage_meta_save', function( $new_product_id, $wcfm_products_manage_form_data ) {
    	global $WCFM;
    	if( wcfm_is_vendor() ) {
    		$vendor_id   = apply_filters( 'wcfm_current_vendor_id', get_current_user_id() );
    		$vendor_data = get_user_meta( $vendor_id, 'wcfmmp_profile_settings', true );
      	$payment_mode = isset( $vendor_data['payment']['method'] ) ? esc_attr( $vendor_data['payment']['method'] ) : '' ;
      	$stripe_user_id = get_user_meta( $vendor_id, 'stripe_user_id', true );
      	if( !$payment_mode || !$stripe_user_id ) {
    			wcfm_staging_site_set_product_status( $new_product_id );
    }, 550, 2 );
    function wcfm_staging_site_set_product_status( $new_product_id, $status = 'draft' ) {
    	if( !wcfm_is_vendor() ) return;
    	$update_product = array(
    														'ID'           => $new_product_id,
    														'post_status'  => $status,
    														'post_type'    => 'product',
    		wp_update_post( $update_product, true );
    hope this helps
    Steve
    sdel_nevo
    Hi aemr45
    to be honest, no I didn’t, I was hoping that would not need to be done, as it would mean all my existing vendors would not work
    i tested by first disconnecting a test vendors stripe, then reconnecting it
    Steve
    sdel_nevo
    hi
    just spoke to stripe support, apparently, the API can set a grace period for sending out transfers for example 14 days
    but when I test this by
    unticking “Request auto-approve”
    and setting the withdraw mode to
    “periodic Withdrawal” and on the schedule select “every 15 days (Every 2 weeks- Monday)
    the funds are still sent directly to the connected test account
    how can we set the system so that funds are not sent to the vendor for 14 days
    sorry if I’m getting confused over this
    Steve
    sdel_nevo
    Hi Guys
    I have moved my site over to this method from direct charges, and so far so good
    my only problem is this
    if stripe pass the sales revenue to vendors instantly how do we handle refunds when the vendor has been paid,
    is it possible to delay paying the vendor until 15 days after the transaction to allow enough time for refund requests
    We pay our vendors using 3D Secure – SCA & Stripe Split Payment: Separate Charges & Transfer
    If a customer purchased some shoes costing ÂŁ100 on the 1st December, is it possible to defer paying the vendor until the 16th December? this would mean that our stripe account still has the available funds to pay the refund, if the vendor has been paid, and a refund request is made, our stripe account is liable for all of this amount.
    that could very quickly put us out of business
    Steve
    sdel_nevo
    Hi
    well it appears I owe you all an apology
    After speaking to stripe today for well over an hour it does appear that the only way multiple purchases can happen is by Creating separate charges and transfers
    I think its a terminology thing, I don’t understand any of it
    the documentation here https://stripe.com/docs/connect/charges-transfers they have stated during my chat session
    It’s currently in Beta but it’s completely public and functional. The only thing not rolled out is the ability to use Separate Charges and Transfers with accounts that aren’t in the same region (ex. UK platform and US connected account)
    I will have no choice but to move to this method so that the site is compliant with SCA regulations
    the only thing i have to work out now is how i implement it
    Steve
    in reply to: Affiliate payments #96035
    sdel_nevo
    Hi tech2
    it wasn’t released as far as I can tell mate
    Steve
    in reply to: Audio file issues #96005
    sdel_nevo
    Hi Guys
    really sorry to be a pain.
    have you been able to take a look at why audio files in either the product description or short description are not visible to vendors, but appear on the product
    Steve
    in reply to: will updates affect functions.php file? #95600
    sdel_nevo
    You’re most welcome
    in reply to: will updates affect functions.php file? #95521
    sdel_nevo
    Hi mate
    I have a child theme with a modified functions.php file and it’s never been overwritten with updates
    If you are not using a child theme, it could get overwritten when your theme updates
    Steve
    in reply to: Audio file issues #94282
    sdel_nevo
    Hi Guys
    sorry to be a pain, have you been able to take a look at this?
    Steve
