wcfm-santa
-365Day -10Hr -26Min -28Sec
wcfm-santa
WC Lovers
WooCommerce Frontend Manager - Multivendor marketplace vendor dashboard
Forum Replies Created
Viewing 11 posts - 1 through 11 (of 11 total)
  • web-3134
    I would like to do just the same:
    – a new vendor can register using [wcfm_vendor_registration] and is assigned to default membership (I created and set a default membership)
    – later on he can select a different membership (I created more membership but don’t want to show them on registration)
    1) I created a page using the [wcfm_vendor_registration] shortcode but something doesn’t work:
    – verification code is not sent
    – State dropdown list is empty
    – tooltips are not displayed
    is this a javascript issue or what?
    2) how can I modify the link “become a vendor” placed under WooCommerce Registration Form? Now it points to Vendor Membership Page [wcfm_vendor_membership] but I need it to point to Vendor Registration Page [wcfm_vendor_registration]
    in reply to: Map Markers #138665
    web-3134
    Same question (custom map marker) and same problem (map marker wrong position when zooming out).
    in reply to: Vendor Store category #137383
    web-3134
    Ok, thank you very much!
    I am also using the “store list meta filter” widget which is very useful.
    How can I add this field in the filter under the map in Store List Page instead of using the widget?
    Can I also pass (and how) its parameters as attributes in the [wcfm_stores] shortcode?
    web-3134
    Hello, any news about this features?
    in reply to: Vendor Store category #137186
    web-3134
    Thank you,
    it’s fantastic, exactly what I needed.
    Just a few questions:
    1) categories filter field in store list page is too big (full width), how can I reduce its size? (image attached)
    2) if I activate STORE categories filter then PRODUCT categories filter disapper from the Store List Page, but I need both, how can I fix this? (image attached)
    3) where is the category ICON displayed?
    4) could the icon be used as a store badge?
    5) could the icon be used to have a custom map marker for each category?
    6) where is store category DESCRIPTION displayed?
    7) with STORE categories filter active, if I filter using a category with no store associated, all the stores are displayed instead of a “no store found” text result
    Thanks a lot for your kind help and congratulation for this great plugin.
    in reply to: Vendor Store category #135936
    web-3134
    after reading your post
    https://wclovers.com/forums/topic/how-to-add-wcfm-available-groups-to-the-vendor-registration-form/#post-129673
    I didn’t add my request but wrote directly to
    https://wclovers.com/setup-guidance/
    as indicated in your reply to someone’s else request.
    in reply to: Vendor Store category #135929
    web-3134
    I need the same add-on. I already enquired after reading a similar topic but had no answer.
    Please help.
    in reply to: Default check "Catalogue" #135090
    web-3134
    Hi @Sushobhan,
    that is exactly what I needed, now I can set “catalog mode” as default for Base Membership and let “normal mode” for all other memberships.
    in reply to: Default check "Catalogue" #133840
    web-3134
    is it possible to set catalog mode only for a specific membership and normal (sell available) to others?
    in reply to: Custom Page direct to specific vendors #132586
    web-3134
    Hello, talking about a dynamic list I’d like to do the following:
    1) add a custom taxonomy to stores
    2) filter stores by taxonomy and get a list of stores
    3) use this list in [wcfm_stores includes=”MYLIST”]
    Once I use a filter on this page (for example radius), are results filtered using MYLIST or using all available Stores?
    in reply to: Multiple Stores Owned By Admin #132568
    web-3134
    Hi, I would like to do something simpler: in order to populate the Store Map and the Store List, I would like (as Admin) to add a number of Stores without Products (let’s say a listings website) so no sell is involved at the moment. Later on the real owners can claim those businesses (like you can do on Google or Facebook) and become Vendors. Is it possible? Any idea on how to do it? At the moment I think that I can just have a Store assigned to a Registered user as a Vendor, meaning 1 Store per 1 User, am I right?
    I could use a standalone listings plugin, but then I will have 2 separate maps: 1 map with listing businesses (all added by Admin) and 1 map with stores (WCFM Vendors).
    Please let me know if there is a workaround. Thanks.
