Forum Replies Created
paul-8288
ParticipantBrian cant seem to reply/login to this forum to reply to you, but said you can contact him over on the unnoficial FB page here
https://www.facebook.com/groups/users.of.wcfm.marketplace/?fref=nfPaul
paul-8288
ParticipantNever mind I figured it out 🙂
For anyone else, archived products is basically unpublished, so just go into it and publish it and it will show on the site again.
paul-8288
ParticipantThis reply has been marked as private.paul-8288
ParticipantThis reply has been marked as private.May 15, 2020 at 7:41 pm in reply to: cant see data in admin side look in image he dont load anythink… #131425paul-8288
ParticipantHI Sushobhan, I have managed to fix this issue.
The problem was twofold, 1 the cloudflare cache was storing a copy of the qtip js file which was causing the issues, 2 we were minifying the qtip file to speed up the site, this was working fine beforehand but since the changes, this file cant be minimized so we turned that off and it seems to have fixed the issue.
Glad to see your doing work on speed, our site is quite slow, anything else you can do it much appreciated, particularly if you can load CSS/JS only on the pages its required and in the footer where possible
PaulMay 14, 2020 at 11:35 pm in reply to: Error! on the WC desk inst showing anything on the list #131068paul-8288
ParticipantApparently its a cache issue and tell you to clear your cache. But there are other people with the same problem, maybe you will be best following this thread, than starting a new one.
https://wclovers.com/forums/topic/cant-see-data-in-admin-side-look-in-image-he-dont-load-anythink/
May 14, 2020 at 11:33 pm in reply to: cant see data in admin side look in image he dont load anythink… #131067paul-8288
ParticipantYes, I had already done that.
Browser cache
Varnish Cache
Op Cache
Page CacheAll cleared, force reload many times.
Even disabled our caching plugin, same problem. Only fix is to roll back.
May 14, 2020 at 11:15 pm in reply to: cant see data in admin side look in image he dont load anythink… #131050paul-8288
ParticipantThanks, did you read my posts?
All my vendors were having the same issue, this was not isolated to my machine. I also turned off all caching and tried in a different browser, same issue. The only thing that worked was rolling back to a previous version of the plugin.
May 14, 2020 at 9:42 pm in reply to: cant see data in admin side look in image he dont load anythink… #131020paul-8288
ParticipantJust another update, I rolled back WCFM – WooCommerce Frontend Manager to version 6.4.8 and everything works fine again. I tried reinstalling 6.5.0 and the same issue occured so I rolled back to 6.4.8
May 14, 2020 at 9:08 pm in reply to: cant see data in admin side look in image he dont load anythink… #131009paul-8288
ParticipantConsole is throwing the following error in wcfm-script-core.js
Uncaught TypeError: jQuery(...).qtip is not a function at HTMLSpanElement.<anonymous> (wcfm-script-core.js:3) at Function.each (jquery.js:2) at n.fn.init.each (jquery.js:2) at initiateTip (wcfm-script-core.js:3) at HTMLDocument.<anonymous> (wcfm-script-core.js:8) at i (jquery.js:2) at Object.fireWith [as resolveWith] (jquery.js:2) at Function.ready (jquery.js:2) at HTMLDocument.J (jquery.js:2)May 14, 2020 at 9:01 pm in reply to: cant see data in admin side look in image he dont load anythink… #131001paul-8288
ParticipantI have the same problem, after updating all WCFM plugins including ultimate today, none of the admin menus work.
No Products show
No vendors show
No orders showThis happened immediately after the upgrade. I was using the site fine before it.
You must be logged in to view attached files.paul-8288
ParticipantAnyone?
paul-8288
ParticipantThanks for that, and for store listing in the stores/vendors page like the attached, what would I change?
My images are not showing up.
ParticipantHI, I am using flat some theme which has its own UX builder, I don’t want to add Elementor too.
I don’t like the tabs, I want to insert a different header, move the buttons around, change the layout of the shop ‘cards’ etc. Ideally I would like to integrate UX builder but I don’t think that’s possible, or at lease use their blocks to be able to edit pages.
thanks
Paulpaul-8288
Participantha ha no worries, self interest, I want to see how the 3D card works in a live env and if the client gets the split pay or not.
paul-8288
ParticipantSorry should have said, that error basically means you havent input the 2 redirect urls in stripe settings. Dont forget live and test are different keys/ids.
paul-8288
ParticipantCan you post a screentshot with the client id partially hidden of your stripe settings in WCFM and also your stripe connect settings? In stripe goto settings at the bottom, and then click on connect settings, it should take you to this page
https://dashboard.stripe.com/settings/applicationspaul-8288
ParticipantYou probably have test data switched on in WCFM payment settings, dont forget to update the keys with the ones from your live stripe settings. Also from that screenshot it looks like your creating express or custom accounts in stripe, if you want standard accounts, have a look at the fix I posted here
https://wclovers.com/forums/topic/connect-vendors-to-stripe/If you want to carry on testing, try using it with this card number, in test mode this forces it to use a 3D secure card and where it keeps failing for me.
4000000000003220.But if you get it setup live, let me know.
paul-8288
ParticipantYes but you might need to look at Payment METHODs API also to provide full connect functionality.
Thank you.
paul-8288
ParticipantDid you get this working? I have the same problem, if I enable 3D secure then the connected account get no payment, if I disable 3D then it works fine and the connected account gets its payment. This is in test mode, the connected accounts should still show the transaction being transferred in test mode. Its only when 3D is enabled it doesn’t work properly, money is then not transferrable for 7 days because the connected accounts/accounts are not flagged in the API.
paul-8288
ParticipantYes, but I was wondering more from your point of view, do you have to wait for the funds to clear before you pay the vendors?
paul-8288
ParticipantYes thanks I worked this out.
Do you plan to use the new Payment Methods API so we can choose our payment options, this fixes all the above problems.
n your opinion do you think that in the near future stipe will update the charges API
– Hope so. That’s the reason we waited so long and release SCA compatibility update at very last moment
paul-8288
ParticipantWith stripe moving away from the charges API, and going to the Payments intent API,they have now created a new payments method API which uses intent to provide different ways to handle payments.
Full details on how to use the payments Method API with connect accounts is here, this should mean we can have full choice on accounts, payment types etc.
https://stripe.com/docs/payments/payment-methods/connectDetails on the Payment Methods API generally is here
https://stripe.com/docs/payments/payment-methodsAlso did you know the ‘connect’ button for vendors now defaults to ‘Express’ connect accounts, not standard, so anyone who has updated may notice new vendors are connected with an express account now.
paul-8288
ParticipantI have been having a play around, adding this to my Themes functions.php file seems to do the trick, looking at past topics it appears that it is now defaulting to express rather than standard.
add_filter( 'wcfm_is_allow_stripe_express_api', '__return_false' );- AuthorPosts
